Hello, my first post here, but have viewed many other posts to help me.
This is my setup:
600w total solar (I think its in series, its technically not my system so am learning still)
Outback Flexmax 60
6 Lead Acid Group27 batteries, in 3 parallel strings of 2 batteries each in series, ~100Ah each = 300Ah
Trace 4024 inverter/charger
Generac LP3250
A little more info before my question:
We had the system installed by a "professional" of 30+ years, so after fixing his battery connections and replacing all 10 batteries with 6 "reconditioned ones", we are here.
We are trying to power the following things. Lets assume we are using them all at once, I just want to know how long they will last.
1 laptop, power block says "100V 1.5A" and "19V 3.42A"
1 laptop, power block unknown yet but lets just double the one above
1 9.9w LED bulb
1 53w ac halogen bulb
1 unkown ac bulb, lets double again
3 1141 dc bulbs
The calculation I made is as follows, but this is the first question with it: "am I calculating amps correctly"
(some are rounded up)
1 laptop 3.42 A (I chose that because supposedly laptop use around 65W, which it totals using that amperage, 19V x 3.42A)
1 laptop 3.42 A
1 LED bulb 0.089 A
1 53w bulb 0.44 A
1 bulb 1 A
3 1141 1.5 = 4.5 A
Total - 12.869 amps (lets say 13)
So, having 300Ah total, and wanting to only use 50% DOD, we have around 150Ah usable capacity.
150Ah/13A = 11.53 hours run time.
Thats my calculation.
Unfortunately, we are using power too fast.
I think its either:
#1 We are using more electricity than I know of
#2 The batteries are 20Ah (meaning really ****ty and not 100Ah)
#3 Or my calculations are incorrect
Id like to assume the batteries are in good condition and that we are using less power than I stated.
So I would like to first tackle calculations.
~ For everything, we are going DC, to AC, then to DC/AC again.
Laptop are DC -> AC -> DC (right?)
~ So, do I calculate amp draw using DC or AC?
~ How about my 9.9w LED bulb?
It says ON the bulb 9.9w, 0.089A, 120VAC
My power coming in is around 110V!, does that change things?
Arent LED's dc? If so that means theres a converter in the bulb, so its going DC -> AC ->DC as well?
How do I calculate it all if I dont know whats using AC and whats using DC?
I know using DC or AC will dramatically change the amp usage calculation. Please help.
(Recap:
~ assuming batteries are good. Are reconditioned good? If not, then how low would a 100aH battery go to upon reconditioning?
~ do I use DC or AC calculations? or both?
~ also, the owner wants to buy (as many batteries as it takes to add on), all my research says running more than 4 parallel strings wil imbalance things, but how bad? Is it worth trying to talk out of?)
Thank you in advance! The more solid info the better
This is my setup:
Outback Flexmax 60
Generac LP3250
1 9.9w LED bulb
3 1141 dc bulbs
1 laptop 3.42 A
1 LED bulb 0.089 A
1 53w bulb 0.44 A
1 bulb 1 A
3 1141 1.5 = 4.5 A
I think its either:
(Recap:
