This is great information. I would love to put up a second array!!, but the jnstaller said the system would not handle anymore panels. These batteries are 6 volts 1100 amp/hrs, having 12 of these should I not have 3300 amp/hrs total? You are correct 80 amp max in good sun, and having We can go 10-14 days with no sun here, and the panels will only take 300-500 watts through each day. I normally run the generator for 1/2 to 1 hr before going to work in the morning, and when I get home I run it for 2 hrs each night on bad days. I have been trying hard to replace what I use each day. When we do laundry and have showers we run the generator regardless. The pump and machines draw too much power. Another big mistake I made is not getting an auto-start generator to work with the charge controller. Thinking of doing this at some point. I will learn all of what you mentioned, and respond. Thank you so much for your time and information!!!
Set-up and performance
Your installer is an idiot. He is correct your charge controller input power limit is 2400 watts on a 24 volt battery. On a 48 volt battery the limit is 4800 watts. He is an idiot for not knowing a C/20 charge current is only half way there to C/10.
Read this and you should get a rough idea of what I am talking about. In fact read all the Stickies written by me in the Off-Grid topic and you should have a pretty good idea of what is going on and figuring out where you stand.MSEE, PEComment
