I have a Server system that I wan't to power using solar, but have the grid available as a backup.
The way I'm planning on doing this is as follows:
I'm planning on having a solar array that charges batteries, and a power inverter to transform the power to AC power for the Servers. At first, due to cost, I'm not going to be generating enough solar power to run 24x7 and I thought the best solution would be to use a power transfer switch, but in reverse. I would connect the power from the inverter to the spot on the inverter you would normally connect grid power, then power from the power grid to the generator spot. This way once my inverter cut out the power grid would supply power until solar could take back over.
Is this ok to do? The load would only be 200 watts at first, then 500 total.
