Organic Farmer
Thanks for sharing your set up.
We will be using a Walltherm wood stove along with two storage vessels.
Plan on using four hydronic solar panels which should get us by from May to September for our domestic hot water and heating needs.
When the panels don't generate enough heat we will have to light the Walltherm.
Wallterm uses a secondary burn chamber for gasification. This should work when we are at the house.
The water storage vessels have an option for two electric heating elements. Can install either 2x2kw or 2x4.5 kw electric heating element.
The micro hydro from what I understand will need a "dump load" once the batteries are topped off.
Thinking that this might be the place to put the excess power being generated in our absence ?
Cooking will be with a propane stove.
Just in case that I cannot get enough heat with the above setup while we are south.
Will rough in for a propane fired condensing boiler or a combi boiler.
