In the dreaming and planning stage presently. For a 48 volt system, would 24 x 2V 1,100 AH batteries and 18 x 250 Watt solar panels be sufficient for an area which averages about 4.1 hours of sunshine daily and for a home which consumes roughly 11 KWH per day on average? Would this all pretty well balance out, or is something way off base here?
Batteries and Solar Panels required to accomodate daily avg. need for 11 KWH
Forget average daily sun hours for off grid. You use worse case in winter like December/January Sun Hours.
As for battery they can provide about 11 Kwh/day so you got that right. With 4500 watts of panels if your minimum Sun Hours in winter are 3.5 hours or longer should produce at least 11 Kwh per day with clear skies. If less than 3.5 hours will need larger panels or more fuel for the generator.MSEE, PE -
As for battery they can provide about 11 Kwh/day so you got that right. With 4500 watts of panels if your minimum Sun Hours in winter are 3.5 hours or longer should produce at least 11 Kwh per day with clear skies. If less than 3.5 hours will need larger panels or more fuel for the generator.Comment
Regardless any off grid system is required to have a generator. The size of that generator to minimize fuel burn and minimize run time should be able to supply the batteries a C/8 charge current. C/8 for 1100 AH = 1100 AH / 8 Hours = 137.5 amps. It would take a 10 Kwh generator to do that. !37 amps is an odd number and 48 volt 100 amp rectifiers are common and would require a 7 Kw genny to power it.MSEE, PEComment
Regardless any off grid system is required to have a generator. The size of that generator to minimize fuel burn and minimize run time should be able to supply the batteries a C/8 charge current. C/8 for 1100 AH = 1100 AH / 8 Hours = 137.5 amps. It would take a 10 Kwh generator to do that. !37 amps is an odd number and 48 volt 100 amp rectifiers are common and would require a 7 Kw genny to power it.Comment
It has built-in AC charger which is the same thing basically. The charger uses either commercial AC power or generator if AC is unavailable and generator is available.MSEE, PEComment
