Is it possible to safely wire 20 Kyocera 250 Watt solar panels into a single Outback Flexmax 80 Charge Controller? I'm in Ohio, and the record cold temperature for this state was -26 degrees F, 104 degrees F. is about as hot as it gets, though I would assume that rooftops can well exceed that. The specific model number of the Kyocera panels is KD250GX-LFB2. Voc= 36.9 volts, and Isc = 9.09 amps. Vmp = 29.8 volts, and Imp = 8.39 amps. Temperature coefficients are: Voc = 0-0.36 deg. C, and Vmp = -0.52 deg. C.
I'm trying to decide between one of the Midnight Solar Classics (150, 200, 250) and the Outback Flexmax 80. Cost seems to favor the Outback unit.
