Hi All,
Im looking at using a MorningStar MPPT 15 amp regulator, only prob is I have about 17amps in full sun. This could produce over 20amps in cold weather and with MPPT im heading towards 25amp spikes.
Ive been thinking about a two separate banks, in the morning i get a solid 14 to 15 amps catching the early sun, around midday the panels are on angles so that they only get a maximum of 14 amps with MPPT, then in the afternoon I catch a good extended afternoon sun.
More sun hours, not breaking the 15 amp barrier, getting MPPT advantage, the morning and afternoon sun is also cooler making for better MPPT.
I have the following panels. Amps are true amps (hot cells)
PANEL AMPS
40WATT 2.1
40WATT 2.1
60WATT 2.75
60WATT 2.75
60WATT 2.75
60WATT 2.75
OLD PANEL 1
Im thinking Ill break it into
east morning
40WATT 2.1
40WATT 2.1
60WATT 2.75
west afternoon
60WATT 2.75
60WATT 2.75
60WATT 2.75
OLD PANEL 1
Ill have to do some testing to find out what angle I need for midday sun to sit under the 15 amps.
Next problem is MPPT wont find true MPPT as half the bank is running at lower power when the other is at full sun. Full sun bank will have lover voltage and out of sun bank higher voltage.
Answer might be to run the panels in series at 24v into the 12v bank, this would mean the regulator would see basically one panel sitting around 32v and would just find the MPPT of that. Id have to ditch the 1amp old panel, and run the panels in groups of 2s for the 36v.
The 40watt panels could do the afternoon shift.
PANEL AMPS
40WATT 2.1
40WATT 2.1
60WATT 2.75
60WATT 2.75
60WATT 2.75
60WATT 2.75
OLD PANEL 1
east morning
40WATT 2.1
40WATT 2.1
60WATT 2.75
west afternoon
60WATT 2.75
60WATT 2.75
60WATT 2.75
OLD PANEL 1
