I have three separate 'lines' of solar panels in my array. The first line is two 'strings' of 4 x 80 watt panels (12 volt each) for 640 watts of 48 volt power. They are wired in series (48 volts) and parallel (the two groups) for one 'older established' circuit running to a Trace PWM controller. That current runs into the 'back' end of the battery bank. But, really, each panel is rated at 17.5 volts so, when the sun is shining I am getting over 60 volts.
I am adding 2 more strings of 3 x 240 watt panels (24 volt panels each) putting out almost 90 volts or close to 1500 watts of power. This second 'grouping' runs to the second charge controller. It is an MPPT OUTBACK and I am wiring it into the 'front' end of the battery bank.
I have 12 x 220 ah (8D) batteries forming three banks of 48 volts each. The larger 2-string (240 watts) section is feeding an OUTBACK inverter/charger.
So the question is: any problem with a PWM charge controller putting in juice from the back end of my battery bank while another charge controller (MPPT) goes in the front?
Admittedly, I know nothing. But that is what the forum is for, right? Please be kind....
