I was planning to wire 4x100W 12v panels in parallel on an RV and find myself getting more confused as to how far I need to go with (panel) fuses. (I'm fine with the CC to battery fusing)
Intending to wire 2 sets of 2x100W panels on the roof with MC4 bridge connetors.
Each set would then have it's own dedicated wires running down inside the trailer. (2 - 40' 8awg MC4 cables cut in half for a 20' run)
Here's the hard part for me...
From what I loosely understand (very loosely), it would be adequate to fuse each of these 2 leads with a 15-20A fuse.
If any one panel shorted, it would then only eat the other panel's output (not 3 other panel's output) - and wouldn't be a problem (they have 10awg wiring).
And then I just bridge/parallel those two sets after the fuses and before the CC (near the CC).
In case you're wondering why I'm thinking of this layout - it's just seems cheaper and easier to just spend $50 on a second 20'x8awg run into the trailer rather than dealing with the hassle of exterior junction boxes, holes in the roof, and/or more exterior grade fuses or connectors. I could be wrong - but it seems simpler at minimal extra cost.
