Hi all! This is my first post to this forum and I'm quite new to the solar panel world. (I apologize if my english is confusing, it's my third language. Please do correct me if I'm using words incorrectly and feel free to ask me to rephrase if something doesn't make sense.)
My parents in law has a cabin that currently uses a mix of propane (stove and refrigerator/freezer) and batteries (TV, radio, lightning, water pump). The goal is to get rid of the propane powered refrigerator (huge consumption) and greatly reduce the need for using the diesel powered generator for charging the batteries.
This is the current setup
Diesel generator outputs 230V AC to battery charger (12 V/25 A or 24 V/12.5 A).
Battery charger is connected to 4 EnerSys PowerSafe 12V155FS (12V, 150 Ah) batteries, all in parallel (600 Ah).
Batteries are connected to an inverter (12v DC -> 230V AC, 2kW continous output, 4 kW max).
Inverter is connected to an UPS which supplies the appliances.
In short during normal usage: Batteries -> Inverter -> UPS -> Appliances.
Now I'm hoping you could help me choose a small (?) system to charge the batteries using solar panels.
More info
- Cabin is located in Sweden and is mainly used during summer (june-september).
- The roof has about 60 m^2 in the correct direction (south) and has about 8 hours per day without shade.
- Energy usage: 1 refrigerator/freezer + water pump + TV/radio/lightning. My guesstimate is 1 kWh + 0.25 kWh + 0.25 kWh = 1.5 kWh per day.
- During summer it is used by several families and the refrigerator should be kept running. For the rest of the year it's no problem to start the diesel generator to charge the batteries for the occasional visits.
Requirements
- The total cost must be significantly below 1000 €.
- Enough energy in to the batteries to significantly reduce usage of diesel generator during summer time.
My first guess
- About 600 W PV panels should be plenty. 4 150 W ECO-WORTHY cost about 600 € delivered. Are these any good?
- About 8 m cable required from PV panels to batteries. 10mm^2 cable should have low enough losses.
- CM6024Z Solar charge controller connected to batteries as is.
Configurations
1a. The simplest route that uses most of existing things is getting a simple PWM Solar charge controller that only charges the batteries as is (12 V, paralleled) and keeping the UPS connected to the batteries. This does however not solve one of the existing problems: The batteries are not protected against being emptied to much.
1b. A version of the above is to set the Solar charge controller between the batteries and the inverter. The UPS is however marked with 1600 W -> 1600 W/12 V = 133 A. I'm unsure whether this is only when the batteries in the UPS are low or if it's any time it charges them.
2. Change the configuration of the batteries to 24 V and exchange the inverter to one that converts 24 V DC to 230 V AC. This reduces the amperage on the Solar charge controller (cheaper) and the losses in the cables from the panels to the controller (higher voltage).
3a. Using a MPPT controller that accepts a higher input voltage (series PV panels) but keeping the rest connected as is.
3b. Using a MPPT controller and setting it between the batteries and the inverter.
Solar Charge Controllers
This is where I feel I'm more lost than anywhere.
A: CM6024Z. Simple PWM controller. 60 A. About 50 € delivered. Maximum 12 A from, cannot be placed between batteries and inverter.
B: I've seen the Tracer 4210RN being recommended. About 140 € delivered.
Questions
I. Series or parallel PV panels. Are there any downsides with connecting them in series except more expensive controllers (due to higher voltages)?
II. Could the implementation be ramped? Say by buying 2x150 W panels and a decent controller (the Tracer?) and then add more panels if needed.
III. Is there a problem connecting the battery charger (powered by the diesel generator) to the batteries at the same time as the Solar charge controller?
Sorry about the very long post, I felt that there was a lot of info that affects how the solar panels should be implemented.
/Anton
More info
Requirements
My first guess
Configurations
Questions
/Anton
