Thank you very much for the explanation. I am going to note battery voltage as shown on the MPPT and multiply that by the amps shown, I should then get more or less the wattage shown at that time, minus the losses. So the wattage will be a bit higher than the calculation, correct? Due to 95% efficiency.
MPPT vs standard PWM?
Thank you very much for the explanation. I am going to note battery voltage as shown on the MPPT and multiply that by the amps shown, I should then get more or less the wattage shown at that time, minus the losses. So the wattage will be a bit higher than the calculation, correct? Due to 95% efficiency.MSEE, PEComment
1. The CC continues to deliver a regulated voltage, without direct PCM by shifting the input away from MPP until the continuous power from the panels is all that is needed to maintain the battery terminal voltage.
2. The CC delivers a PCM voltage to the output by shifting the input side between open and MPP in a PCM fashion.
3. Some other variation.
I do not know what any particular actual CC does. But the key thing is that in all cases the power taken from the panels will be less than PMPP while the peak voltage on the input, as measured with a peak catching DC meter, may be anywhere from below VMP all the way up to VOC.
Can anyone on the forum supply the definitive answer for their particular MPP CC?SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
