New system- 24v or 48v
do you have a budget in mind? I had grossly underestimated the cost, no regrets on my end because I didn't build it to "go green" or "stick it to the POCO". Just so long as you don't think it'll be cheaper than grid power you'll enter it with the proper mindset. Be prepared to spend more than you're probably thinking, the quality equipment is expensive. I spent a good chunk on things I had not factored in, such as panel racking and I had to pay a core charge on each battery because I didn't have any turn ins etc.1150W, Midnite Classic 200, Cotek PSW, 8 T-605sComment
Yes I did, Power is 4 miles away. Part of the charm of the place is just that, off the grid. We just want a little refrigeration and satellite internet while we are there as we both do a lot of work from home. I know that Propane would be a good option for refrigeration but access does not allow big trucks to the cabin and I don't want to be hauling 5-7gal tanks up and back every month. Winter is snowmobile access only. My thought is solar is a little easier.do you have a budget in mind? I had grossly underestimated the cost, no regrets on my end because I didn't build it to "go green" or "stick it to the POCO". Just so long as you don't think it'll be cheaper than grid power you'll enter it with the proper mindset. Be prepared to spend more than you're probably thinking, the quality equipment is expensive. I spent a good chunk on things I had not factored in, such as panel racking and I had to pay a core charge on each battery because I didn't have any turn ins etc.
I am budgeting $5,000 to $10,000 which I think will fund this project. I can't do anything with it until the snow melts anyway so I thought I would get a few thoughts from everyone here as I always am reading about someone who bought the wrong stuff. I just want to do it once.Comment
I see. For the refridgeration part, several of us here have converted chest freezers to act a fridges. I leave mine running at our spot when we aren't there, it isn't as user friendly as a normal fridge but it uses much less power .5Kwh/day so that may mean you could make the system smaller and save some money. Only costs about 60 bucks to do the conversion and the freezer remains unaltered.
http://www.amazon.com/Johnson-Contro...hnson+controls1150W, Midnite Classic 200, Cotek PSW, 8 T-605sComment
Panels 4 250W $1000Yes I did, Power is 4 miles away. Part of the charm of the place is just that, off the grid. We just want a little refrigeration and satellite internet while we are there as we both do a lot of work from home. I know that Propane would be a good option for refrigeration but access does not allow big trucks to the cabin and I don't want to be hauling 5-7gal tanks up and back every month. Winter is snowmobile access only. My thought is solar is a little easier.
Charge controller $500
Inverter $800
Batteries $1000
Misc $400
I would say your budget works.NABCEP certified Technical Sales Professional
...need to add a racking system in there as well and installation if you're not a roofing guy/don't want to chance mounting the panels by yourself1150W, Midnite Classic 200, Cotek PSW, 8 T-605sComment
