Off grid Camper 1,000 dollars to spend.
    Originally posted by MrTanaka
    ... The Coleman cooler appears to be approx 48 watts. ....
    I seriously doubt that the cooler is only 48 watts. I would belive 148watts or 480 watts.
    Since these are used with 110 ac adapters an inverter would be needed. 1000 watt unit good enough?
    Way too much overkill. Your idle losses in a large inverter would be more than than all your loads. You want a small, pure sine wave inverter to power all your electronic gizmos since 20% of them will puke with a mod sine inverter
    • paulcheung
      • Jul 2013
      • 965
      #47
      I think those cooler don't use compressor. it use like 48 to 72watts power and only get 10 degree lower than surrounding.
      • MrTanaka
        • Feb 2014
        • 7
        #48
        On the description, for whats thats worth it does say around 30 degrees below surrounding but....product descriptions get carried away sometimes
        This is the power requirement according to the manual
        POWER REQUIREMENTS
        9.5 to 14.4 Volts DC, 4 Amperes @ 12 Volts DC Nominal
        I used just a 12v rating
          POWER REQUIREMENTS
          Ouch this is where things get painful. 48 watts x 24 hours = 1152 watt hours. That is a huge number.
          Just in battery alone requires a 12 volt 480 AH, $1000, 270 pound battery.
          As for panel wattage depends on location, time of year use, and orientation. Panel wattage could be anywhere from 300 to 500 watts just to run the cooler. Here is the kicker. I have a full size 26 cubic feet French door refrigerator that uses less power than you ice chest.
          • MrTanaka
            • Feb 2014
            • 7
            #50
            Sunking, how is that possible? The cooler is ac/dc and would run thru an inverter if that makes a difference but this is one of the things I don't understand I read all over about people running all kinda stuff of their systems and all I want to do is run a little cooler and I need a 5000.00 system? Very difficult for this pea brain to comprehend. Oh and I really wasn't intending to run 24/7 just a few hrs a day would suffice if that makes any difference as well lol
              ..... I read all over about people running all kinda stuff of their systems and all I want to do is run a little cooler and I need a 5000.00 system? .....
              Paid shills pumping up the Amazon reviews.
              Good Energy Star fridges, consume about 1KWh daily. Little dorm/mini fridges, may actually consume even more than that, because of cheap insulation, gaskets.......
              http://www.coleman.com/Products/8570...ectric-coolers
              40-qt. capacity, holds 44 cans plus snacks
              Iceless cooler chills contents to 40° F (4.44° C) below the surrounding temperature
              12V 4A or about 50 watts (not as bad as I first thought)
              However, 50 watts won't move much heat, about 80% of that, is self heating from the module, things must be pre-chilled.
              That would be a constant 4 amps, till the ambient cools to about 50F.
              in a day, that would be 1200 watt hours, just a tad more that a real fridge with icemaker.
              if you had 5 solar hours, you need to harvest 2400 wh which needs about 600w of panels. A few more watts of PV, and you can run a couple LED lights.
              • MrTanaka
                • Feb 2014
                • 7
                #52
                I hear ya about the paid shill thing Mike I really appreciate all the help and knowledge you guys have provided It seems that a 100w panel will get your cell phone charged run a couple of lights and a fan and not a whole lot more Guess I'll be toting gas for generator around for awhile The idea of solar is awesome but at the present time the cost pretty much outweighs the benefits. Once again thanks for helping me understand
                • thastinger
                  • 804
                  #53
                  You can have refridgeration for .5Kwh/day and the equipment will cost under 200 bones. Based on some discussion here, I converted an 8.8CuFt chest freezer to act a a fridge. I already had the freezer but they are cheap and for 60ish bones I bought a Johnson controls external temp regulator. The cost of your PV system comes down significantly when you cut your loads in half.
                  1150W, Midnite Classic 200, Cotek PSW, 8 T-605s
                    Conservation and load management should always be the first step, as it almost always gives the greatest return on investment.
                    • paulcheung
                      • Jul 2013
                      • 965
                      #55
                      Also if you don't put glass bottle in there you can turn the control a bit colder and make it slightly freeze in the day and turn it off at the night so use the panels instead the batteries; that is what I do with my freezer. I have an automatic switch on the power socket. it turn the freezer on at 8:45 am and turn it off at 4pm, because the door is only open once or twice a day so meat still frozen. and my refrigerator turn on 8am and turn off 8pm when every one leave the kitchen. the drinks and vegetable are still cool in the morning and the meat in the freezer compartment still freeze. only thing I can't do is keep ice cream in there. but that is ok as I am over weight anyway.
                      Cheers
                      • paulcheung
                        • Jul 2013
                        • 965
                        #56
                        Off grid solar world is a total different place all together. you have to work around and be conserve and disipine. I used to use 1000 to 1200 kwh every month and there is no way I can afford the right amount PV system to support that, so I got a PV system with 6000+ watts with two bank of batteries total 750 amp hours at 48 volts.
                        I have to change my life style and be conserve. I change most of my lights to LED lights and turn off most my pond pumps at night and also the freezer and the refrigerator at the nights. so I can use the solar to power my whole house. Lucky thing we don't have Snow in Jamaica and my ceiling are very high so it is not so hot at nights. I make sure tell my helper to do laundry in the sunny days and do what ever heavy demanding in the suny day. That is how I try to meet my demand with the 6000+ watts system.
                        Like your situation. you can convert one of those freezers to work at the day and turn it off at the night so you don't need much battery and get a small generator to charge the battery when the sun is not coming out the whole day. Then you can buy two 250 or 300 watt panels and a mppt charge controller and 600watts pure shine wave inverter with two of those 225 amps batteries which will run you about $1500 with out installation and wires.
                          Paul I have a friend in Jamaica named Paul Williams. He owns a tour company. Look him up sometime and tell him KF5LJW says HOWDY and 73's
                          • paulcheung
                            • Jul 2013
                            • 965
                            #58
                            OK cool.
