So here is the scenario
I am in the midwest near the canadian border. I don't plan to ever use XCEL energy again. I already disconnected the main leads coming in from the power company(into my panel)
The building is a commercial building that I basically use for storage and hobby use ect. About 3500 sq ft building.
I have a boat load of 12 volt LED lights and a boat load of 120volt LED lights.
Heating is by means of firewood.
I have about 150 golf cart batteries that are 6 volt (deep cycle) Brands include trojan, energizer and interstate. I have been playing around with a 1.5 watt solar panel, 3 watt solar panel and a 7 watt solar panel.
I have 4 inverters, 300watt, 800 watt, 800watt and 800 watt.
I have been wiring these in series so I have 12 volts coming from each set of batteries, I then have been hooking up my batteries to an inverter when I decide to do some work in the shop, to power lights, radio ect...
Now I understand light output in my area during the winter is poor, but the 7 watt solar panel charges the batteries very well.
My questions are as follows
1 how should I be charging them? Should I charge each 6 volt battery individually till it reaches correct voltage, or should I keep them wired in series and charge them till they reach 12 volts(or slightly higher).
Or should I bite the bullet and buy a xantrax 36 or 48 volt charger/inverter and hook that directly to my electrical panel on the wall giving all outlets in the building 120volts...
I really don't want to spend thousands of dollars to accomplish this as its only a hobby shop and I am just avoiding paying xcel for monthly service especially in the months when I hardly use the shop.
I don't run fridges, washers, dryers or even a water heater. Highest output appliance is a radio or 18volt cordless drill charger.(maybe a sawzall) so 1500 watts on 1 circuit is at most. The lighting is again all LED so it draws nearly nothing.
I have all the existing wiring from the golf carts so I can wire them all together to achieve the 36 volts or 48 very easily.
I understand the basics of solar, knowing a charge controller, and temp sensor is important. This is in a shop setting that nothing can catch fire, but I would like to be safe and have this done right without spending $1500 on a inverter.
I have wind power available to me during the summer months but the winter months is slightly different. So far I have powered everything in my shop area for 60 days with only 18 batteries(never recharging them)(this is because i only had a 1.5 watt charger and it wasn't able to put any type of charge on the batteries. Now that I Have purchased a 7 watt solar panel it charges a 6 volt battery in no time.
What are my options to make sure I am not causing harm or shortening the life of the batteries.(I understand I don't want to undercharge or overcharge them)
