How to make a solar system for my 2 light bulb (18W) each?
  • Jeffych
    • Dec 2013
    • 8
    Hi. I'm totally new in Solar.
    Would like to know how can I design the system for my 2pcs of 18W light bulb (AC) which operating for 8 hours a day (fr 7pm to 3am)? Thx.
  • Naptown
    • 6880
    Go to the battery design link in my signature and fill out the calculator
    • Jeffych
      • Dec 2013
      • 8
      Thank you for your replied. Unfortunately I still not able to access it yet as I have 0 point in this forum at the moment. How can I do?
        • 15186
        You can find that post by first going to the main Forum page. Look for the section called "Off grid solar" then click on the first post called "Off grid electrical systems". The third "sticky" post is called the "Solar Off Grid Battery Design". That is where you will find the information that Naptown mentioned.
        • Jeffych
          • Dec 2013
          • 8
          Thank you.
          For my case..
          18W x 2pcs = 36W
          Watt per day = 36W x 8hrs (operating hr) = 288Wh
          Multiply by factor 1.5, 288Wh x 1.5 = 432Wh
          Assuming the total sun hour I hv is 4.5 a day..
          Solar panel suitable for me is 432Wh ÷ 4.5h =96Wp which is ~100Wp
          For the battery, 288Wh x 5days ÷ 24V = 60Ah
          For Charge Controller, 100Wp ÷ 24V = 4.16A which is ~5A
          Is it my calculation correct?
          How about the inverter? As my load is in AC mode. Is there any calculation for it?
          Sorry, as I really new in this field.. really hope that you can help up. Thanks.
          • Naptown
            • 6880
            If that is all you plan to run get somewhere around a 100W inverter.
            • Jeffych
              • Dec 2013
              • 8
              Thank you Naptown.
                Are the light bulbs incandescent, fluorescent or LED? You might be able to save money overall on your system by using more efficient light sources and smaller batteries and panels.
                • Jeffych
                  • Dec 2013
                  • 8
                  Is a normal bulb as we need to use it for some special application.
                  By the way, what is the estimated cost for 100Wp solar panel & 60Ah battery in the market currently?
                  And the inverter must be in Pure Sine wave?
                  • Naptown
                    • 6880
                    incandescent bulbs will not require a pure sine wave inverter modified is OK.
                    But a question that does arise if this is for for a particular application how critical is light output and the tolerance.
                    • Jeffych
                      • Dec 2013
                      • 8
                      Noted. Will test it out & see.
                      By the way, I did a calculation if I use 2pcs of 5W LED bulb, I only need 30Wp Solar Panel & the charge controller is about 1A.
                      • Shockah
                        • Nov 2013
                        • 569
                        Why not 12 volt LEDs? ...
                        Eliminates the need of an inverter.
                        [CENTER]SunLight @ Night[/CENTER]
                        • Jeffych
                          • Dec 2013
                          • 8
                          Noted. Thanks.
                          • Shockah
                            • Nov 2013
                            • 569
                            Are you stating you need a bulb for a special application? If so, what is the application?
                            Otherwise, If you need a simple dusk-to-dawn lamp, there are several designs available.
                            Choice would depend on how bright you need it and budget.
                            • Jeffych
                              • Dec 2013
                              • 8
                              I'm using the normal bulb to attract insects during nite time for my biological project.
                              I tried to use the LED bulb in my research before, but it seem like the results is not so good. That's why normal bulb is needed.
                              By the way, I try to recalculate it again as the operation hours reduce from 8hours to 4hours as below,
                              18W bulb x 2pcs = 36W
                              Operating hour per day = 4 hours
                              Watt per day = 36W x 4hours x 1.5 (factor) = 216Wh
                              Assuming the total sun hour = 5hrs a day
                              Solar Panel I need = 216Wh / 5hrs = 43.2Wp which is ~50Wp
                              SLA Battery,
                              36W x 4hours x 5days ÷ 12V = 60AH
                              Charge Controller,
                              50Wp ÷ 12V = 4.16Amp which is ~5A
                              Is my calculation correct?
                              For the inverter, as the Solar panel is 50Wp, I choose 50W Inverter. Is it correct?
                              Please input me with your comments. Thank you.
