I hope this is posted in the right section
I am fairly new to solar and mainly use it for camping/expedition use on my truck for extended stays away from traditional camp sites. I use my solar to keep my AUX battery (100ah group 31) charged up to run my 600w inverter, ARB fridge and other accessories.
I purposely overbuilt my system so i can add/support more panels later. Here is my current setup that i worked with Amsolar to build:
100w GS100 panel
25ft 10g wire (allows me to park truck in shade and move panel to sun)
this extension wire goes from the panel and then plugs into my truck bed (via MC4 connectors) where there is about a 6' run of 8g wire to my Blue Sky Solar Boost 2512iX-HV MPPT
I use the Blue Sky IPN PRO Remote Meter to monitor everything
I have questions on adding additional panels.
While 100w is typically enough, I find there are times i need some more power on some trips. I am thinking of adding a 100w foldable panel - essentially 2 50w panels connected nicely like this:
I have been reading about connecting the panels and wanted to see if I am doing this correctly.
I was going to terminate the output of the 2 50w panels with MC4 connectors (vs going to the charge controller in the image) then using MC4 multibranch connectors to run my single 100w panel to the folding panel in parallel like this:
Would this be a correct way to set this up? I want to use the multibranch so i can bring in the additional panel as needed (vs a more permanent combiner box). I have been reading about the use of bypass diodes - are they necessary in this setup?
I also feel i am getting close to the limit of my 25ft 10g extension cable but I think it will suffice for a 4-5% loss.
Any comments or suggestions are welcome - thanks!
100w GS100 panel
