[QUOTE=Mustang65;91144]Pretty neat system you have there. The only place I see a potential problem is the lack of a fuse between the Ramsond inverter outlet and the 30 amp receptacle that you plug your shore power cable into. There is no overcurrent protection should you plug too much 120 load in the RV since it is set up for 30 amp at 120volt and the inverter output is less than that.
Solar on my truck camper
[QUOTE=SunEagle;91145]When I started wiring in the system, I checked with Ramsond support and they (for what it is worth) said that each of the outlets on the inverter have internal circuit breakers. I have yet to pop one, but if it can, I will pop one sooner or later. I would have 2 additional outlets on the inverter to get me through the crisis. I am going to upgrade and install a circuit breaker next to the inverter, hopefully before I start camping again. ..... and of course I am never satisfied so I will be adding additional solar power/batteries.
Pretty neat system you have there. The only place I see a potential problem is the lack of a fuse between the Ramsond inverter outlet and the 30 amp receptacle that you plug your shore power cable into. There is no over current protection should you plug too much 120 load in the RV since it is set up for 30 amp at 120volt and the inverter output is less than that.
Thanks for the concern
Don
2013 Jayco Eagle 284BHS
250Watt Grape Solar Panel, MorningStar MPPT 60 Charge Controller
1500 Watt Ramsond PSI, 2 Trojan T145 Batteries
2 - AirSight Wireless IP Cameras (used as rear view cameras)
EnGenius WI-FI extender, Netgear wireless modem (n)
MagicJack Internet Phone
2012 Ford F150XLT, EcoBoost w/3.73
157" Wheel base, HD Towing Package
Our Solar RV Album http://www.solarpaneltalk.com/album.php?albumid=145Comment
first things first
[QUOTE=Mustang65;91144]and possibly a 3-way refrigerator (11.2 amps is a number I came across for the fridge running on DC) if there is enough battery capacity.
Just so you know, on a 3 way fridge you can run it on LP and the only electric needed is a few mW of 12 volt power to run the circuit board.
Running a heater fan on even my batteries will bring them down by morning to 12.4 Volts, and I do not like to drop below 12Volts.
If you decide to purchase a Gas Generator, understand campgrounds do not allow the noisy ones, that everyone can afford, pretty much it has to be the silent running ones like Honda (about $2k)..
You can only run the generators between the hours of 9 and 9 at most campgrounds, if they are the quiet types.
LED's are a must
With my setup I can watch TV (inverter), listen to the radio, laptop computer,charge phones... all day (solar charging) and at night until about 11PM, with LED's for lighting, we have not had much need for heat, but that is a battery killer (the fan).
Good Luck
Don
RV furnace must go big power draw very inefficient about 50 % get a Blue flame heater 99.8 % use the space from throwing out rv heater for battries...
http://www.northerntool.com/shop/too...5466_200395466
Now this is RV solar
http://www.solarpaneltalk.com/album.php?albumid=99Comment
[QUOTE=dkpro1;91150]That is a serious looking solar pv system.
Now that is a nice setup... thanks for the heater tip... probably will not get it past the wife, so thicker blankets
DonComment
Thank you
It took a while to get to this point but it is very good now paid for it all by doing instals on rv's in south AZ. in the winter
ps. we use a elc. blanket at night very low draw set on low ....my inverter is on 24-7Comment
In case I missed it in one of the other posts,
What is the output of your panels?
What do you have for batteries?
Charge Controller?
Inverter?
Nice winter time activity... installing systems.
DonComment
my sys.
I have 2 system's 12 volt and 24 volt
on the 24 volt
1400 watt's grid tie panles aray vmp 37 volts
Morningstar Tirstar 45 mttp
4- T125's in series
Go power 1500 watt Pure Sign
on 12 volt
275 watts 12 volt panles
Morning star sun saver dual .....takes care of 12 house and motor battry
1000 watt go power PS.
2 T 105's
FILL THE ROOF BABY!!!!
run a 5 cf deep freez
and an apartment size ac fridge
40 inch LED tv ..with direct tv
22 inch LED in beedroom
lots of crock pot cooking
took out 1500 watt heating element from hot water heater replaced with 1000 wattComment
