Morningstar MPPT-45, LED meaning
  • fernandonh
    • Jan 2013
    • 39
    Here are the facts:
    - CC voltage reading: 12.5v
    - 250 W panel fully exposed to the sun.
    - LED on CC: Yellow and Red lit together, NOT flashing.
    - only 3 amps coming through.
    This seems odd. As per the manual, Yellow + Red means battery is close to being fully drained while the voltage is at 12.5. Also, if battery were close to empty i would expect to see a lot more amperage being delivered.
    Any ideas of why this may be happening?
    I have the digital front panel meter on my MPPT 60, which also has the web interface.
    Try measuring the PV input voltage, what do you have there ?
    Shut the whole thing down and power it up thusly:
    Connect to battery and wait 2 minutes for the controller to completely boot up
    Then
    Connect to PV, and it should sweep, and ramp up to full power in a couple of seconds.
    But without input and output voltages, can't tell whats up
