Announcement
No announcement yet.
Question about 15 W Solar Panel for boat batteries
  • Filter
  • Question about 15 W Solar Panel for boat batteries
    I have a question concerning the new thunderbolt magnum 15 W solar panel kit that I bought to charge boat batteries. I have mounted the panel on the boat shed where the boat is stored. Will any damage be incurred to the panel if I simply disconnect the leads from the battery when I take the boat out to use it?
    thanks,
    mbeebe
  • #2
    Is there a charge controller?
    Rich
    WWW.solarsaves.net
    http://www.solarpaneltalk.com/showth...Battery-Design
    http://www.calculator.net/voltage-drop-calculator.html (Voltage drop Calculator among others)
    www.gaisma.com
    • #3
      Leaving a solar panel in full sun, and disconnected from a load, will not damage the solar panel.
      ...to the panel if I simply disconnect the leads from the battery...
      This is the concerning part....are you using a charge controller between the solar panel and battery? If not.....your battery will not last very long...
