Hi all,
I'm new to solar and have purchased the following items to run some items in my office, it was never intended to make money, more of a project!
2 * Used 170w panels (Vmp - 35v, Voc - 44v, IMP - 4.86A, Lsc 5.36A (35v * 4.86A = 170.1W)
1 * 30A charge controller (http://www.bimblesolar.com/offgrid/chargers/solar30) - very cheap!
1 * Cheap ebay 500w inverter
1 * Second hand YUASA SWL2250 (FR) battery (link for data sheet) http://www.yuasaeurope.com/images/up...SWL2250_UK.pdf
It's been set up for around a week and gets to the float voltage pretty quickly, however last night I switched the inverter on and run a pc, tv etc (around 200W) for 30-35 mins before the alarm on the inverter started and shut down, the charge controler displayed the voltage had dropped to 10.1v, as soon as the inverter shut down the voltage "bounced" back to 12.5v.
Am I expecting too much from one battery as I presumed I would get around 3 hours usage @ 200w even including losses.
This is how I calculated the battery capacity 76A * 12V = 912w from full (and new) to dead, I suspect the used battery is more used than was advertised, although could anyone shed any light on what to expect from this battery in the real world? I understand that 912w in the battery does not mean 912w to appliances as the inverter will only be 80% efficiency but 200w for 30-35 mins is still pretty poor.
Would it be worth charging the battery to the Cyclic (or Boost) charge - 14.5v as I've read that that can help with sulfation?
Any assistance or advise would be greatfully recieved.
Thanks,
Barry
Thanks,
Barry
