hi im new to the solar scene i have hooked up 8, 245w 52 voc panels in parlell to a 80v max in mppt charge controller i have 8 6v 220 ah golf cart batteries (it doesnt say at what amp the amp hour drain is at) wired in 24v with two strings this bank i sort of stabbed in the dark with and is way under powered.
Q i was trying to use the bank as a buffer as i have a grease car i was trying to use as a generator to top off with beig a 24v system and a 12 v altenator i was wondering if i could tap into the in on the charge controller side to boost the incoming voltage 52 panels +15 on the car. toget 67 ish as i understand i will still get some high voltage on cloudy days but supplement some amps from the car as the panels will drop off right?
Q can i put a diode in line to protect my car from high voltage when connecting to the panels ,will the cars 60 amp current hurt the panels , will the current leak into the panels as it would be cloudy , will my voltage regulator on the alternator be stressed ?will this scheme not likely work? thanks
