Hello!
My plan is to create an attic fan.
The current solar versions do not push enough air for the price you pay. I have a pretty big attic in an old brick home.
I am looking at AC versions for due to their CFM values.
Example: via Amazon
Broan 353 1140 CFM Gable Mount Powered Attic Ventilator
Specs:
120V
3.4 Amps
In this case I will need :
**I know...I know... it is probably cheaper just to run it on AC...but my birthday is coming up so I can have some family member buy some things
Soo...how would one calculate what is needed?
Where do you start first?
I don't want to spend extra on things if they are not needed...ex. buying a 5000watt inverter just because 5000 watts sounds cool.
1. What is the bare minimum to keep that fan moving air during the hot months of summer?
2. How do you calculate if things would change...ex add a second fan?
Thanks!
Greg
Example: via Amazon
Specs:
120V
3.4 Amps
- A Panel
- Inverter
- Battery
- Charge controller
Thanks!
Greg
