That didn't answer my question so until otherwise affirmed that statement simply falls into the category of one man's opinion.  Perhaps it is right.  Perhaps not.
The need to tear a cell down so as to recondition it should in my opionion be a complete last resort when all else fails. I'm assuming that you have never personally opened an Edison cell up for reconditioning and tried to put it back together or I suspect you would not be so high on that "magic bath" procedure you reference. Neither have I as I have not found it necessary. An aquantainace of mine that HAS done the acid dip procedure did not get any better results in performance renewal than I am getting the way I do it. Additionally, if you open the cans up you now have the issue of putting the cans back together without leaving an anodic region for massive corrosion attack in the container (enter Zappworks with their poly shells).
I have reconditioned the bulk of my own Edison cells by a procedure that is low temperature (< 40 C), non-acidic, and non-invasive (don't take em apart) but I will state up front I have not had the chance to work with a ChangHong cell. I think it should work for them too, but truth be know I have not spoken to anyone that has a ChangHong cell that needs reconditioning. I would like to have that opporturnity to see if this new procedure will span over to the new cells if anyone out there has one they would like me to work on.
