While your experiment with those NiCd batteries may work for a while you have to understand that in the majority of the times most "flat line" batteries never get revived to the point of being trustworthy again. You can pump as much "fluid" as you want into them but in the end you will just be flushing money down the drain.
Rejuvenating Edison Flooded Nickel-Cadmium ED-160's and ED-240's
Justin, I have a new set of Saft spl 340, the paper work with them dated 2015-05-07 has a note:#1. Cell oil shall not be used in the cells. #2 No electrolyte changes required. However if you can't get them back to life then nothing to lose, I would try Inetdog's sugestion. Good Luck.
WayneWayne, Virginia, usa.,13kw tracking gt.Comment
I just did a little follow up at the " maintenance of saft railroad batteries" It states for ED and SCM batteries 1/8 inch of cell oil on top of electrolyte. Use cell oil or high grade mineral oil only. No oil to spl batteries. Hope this helps if you have not already found it.
You only need the float oil for long term usage. I'd skip adding it till you discover which cells are viable.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I disagree. I brought 171 cells back to an average 75% of the original specs. Average cell age is 33 years old. I've been running on that bank for just shy of 3 years now.
Sorry for the delayed response. I do not check this forum very often.
Here you go.
Getting a battery back to 75% of it rating may be possible but not always and at what cost. You also have to get rid of all that fluid which is toxic and can't just be dumped down the drain.
IMO there are other ways to save money and reviving dead batteries is not a guaranteed or cost effective or environmental path to take.Comment
