Alert about under-capacity batteries purchased from Alibaba
  • dharry
    • May 2014
    • 27
    In hopes of saving someone from a similar very disappointing outcome, I am posting my experience. I purchased 64 LFP cells from Simon Lin of Dongguan Huanhuan Energy Ltd.n AliBaba.
    I purchased 64 200Ah CALB cells in November 2019, arrived January 6th, 2020. They were connected in parallel and balanced overnight (not charged) and put into service in a 4P16S, 800Ah configuration January 7th.
    Cells have been cycled lightly, typical usage cycle is between 85% to 96% SOC. Twice they were cycled down to between 50 and 60% SOC. Charge rate never exceeded 50A and was usually between 35A and 40A (<0.05C). Absorb is 3.45 or less for less than a half hour. The only time they have been above that until the capacity tests was for a one-time, full-bank, parallel top-end balance at 3.65V.
    During a recent snowstorm and 3-4 days with limited recharge, they reached their low-end cutoff (3.065V, 49.0V bank). The cells were all within 10mV balance at this time thanks to a 10A active balancer.
    At cutoff they had produced 644Ah. There is perhaps 6-7% capacity below 3.065V and the cells began this cycle at 97-98% charged. Therefore, 644Ah should represent roughly 92% of the capacity which indicated conservatively a full capacity around 700Ah, well below 800Ah.
    I purchased two ZKETech EBC-A10H testers to evaluate the capacity of my cells. My tests are done at 20 degrees Celsius as follows:
    Charge cell to 3.65V, cutoff charging when charge current falls to 1A, immediately begin capacity test.
    Capacity test – 10A discharge (0.05 x 200Ah), 2.6V cutoff
    Recharge – charge at 0.001C (1.6A) to 3.1V, then 20A charge to normal.
    I have now tested 19 of the 64 cells and the mean is 164.72 Ah standard deviation of 4.13. Assuming less than 1% capacity below 2.6V and an initial charge to 100% that means these cells are about 166 Ah cells, 83% of stated capacity. Even adjusting a couple percent for testing below standard temperature (20 vs 25), that’s still significantly below spec.
    In hindsight, I should not have purchased these cells until I had the ability to capacity test them. Since the cells are usually cycled so lightly, I was not aware there was an issue until the deep discharge and shutdown. If there is something I am missing or have done incorrectly, please let me know. These cells were advertised as new, 1.5-year old batteries which shouldn’t be a problem for LiFePO4 cells. They were 3.29V when I received them and reasonably consistent across the set. The only explanation I have been able to come up with is that these cells had been used heavily before I received them. If so, not only is their capacity reduced from the heavy use but their lifespan will be much shorter than promised. I have exchanged quite a few messages with Simon Lin since discovering this and have provided him test data and details but he has offered no explanation or resolution.
    Please let me know if there could be something else that is causing them to perform so far below specification.
    • 3649
    You are not alone. A poster on another forum purchased 32 CALB SE 200 cells from the same vendor and they tested at 170 Ahrs. His purchase was in January.
    On the other hand, over the past six months I have purchased forty four 280 Ahr generic LFP cells on Alibaba and they have all tested within 10 Ahrs of 280 Ahrs. I had received quotes on CALBs and CATL and the prices were either too high or I could not get any assurances that the cells had not been used. There are also some grade B cells whose capacity is not the same as the Grade A cells.
    I based my purchase on the experience of 15 or 20 prior purchasers whose experience was good with specific vendors. I fully expected 10 percent of the cells to be out of spec and ordered extras. The price of less than $120 per kWh was worth taking the risk to me but may not be for others.
    It is important to be careful out there.
    • dharry
      • May 2014
      • 27
      thank you &ampster, do you by chance have a link to that post or can tell me what forum it's on?
        • 3649
        I don't think links to competing forums are permitted here but a google search will probably yield useful information, If you to find me on one of those forums that allow PMs I can send you a link.
        With regard to my battery choice I should add that these generic batteries are no where near the quality of CALBs, Winstons or any of the prismatics often used in EV conversions. They are not matched like a quality name brand batteries are matched. The result is they suffer from variations as they approach the knees of the charge and discharge curves. It resembles the voltage sag of Pb batteries on the discharge cycle. Since I was already planning on only using 80% of capacity that did not affect me. It does mean that is is also very important to run these with a BMS so the deviations can shut of the pack should one cell be a runner. My point is that with an appropriate risk management strategy the outcome can meet ones goals.
        As far as the bottom line is concerned, at a price of $120 per kWh or $150 per kWh of usable capacity they were cost effective for me compared to the used Nissan Leaf Frankenpack that I had been using. I was also glad to make the transition to LFP which is a much safer chemistry than the cells containing Cobalt. They got me through the PSPS power outages this year. With the spare cells I purchased and some inexpensive inverters, I built some 12 volt packs to keep the refrigerators running for some relatives during those outages.
