Nochi - no problems. These are forums where there is no body language, tone, and even a difference in the way one expresses themselves in print rather than speaking. Too many forget this, ie I'm sure we'd all have a blast if we were on a cruise together!
Real quick - unless you have some sort of lifepo4 specific controller, we shoehorn those intended for lead acid. Ok, in this case be SURE to disable any sort of temperature compensation! That will easily put you well under or over charged if left operational. One trick if you can't disable it is to set any temp comp values to plus/minus 0.00 v in the menus... Heh sneaky.
FLOAT - we can fool the system by setting this abnormally low. What happens is that during a normal charge, say one that has gone through CC (bulk), entered the CV (voltage limited) stage, and is doing it's thing and eventually riggers to the much lower float voltage (because say you can't disable it).
If you watch your current, you'll see that there is NO current flowing at the float voltage it switched to. So in the case of your typical 12v lifepo4, bring the float voltage value UNDER 3.45v per cell.
This is the one thing that we can remember - 3.45v per cell *under charge* is the *minimum* needed to achieve a full charge given enough absorb time for LFP. So if you set your float voltage well under this, when the controller kicks into float, you'll either have zero current, or very little - so little and by virtue of being lower than 3.45v per cell, it will never over charge. The battery has already satisfied the SOC so high with normal charging, that float (SET TO LOW VOLTAGES) has very little effect.
Advantage of a very low float setting? Ah, we can shoe-horn this lead-acid feature as kind of a battery safety feature - that is - what if you have some sort of tiny short, or parasitic load like an alarm, or some other gadgetry that doesn't immediately seem to be visible?
In one controller I had for my 12v lfp, and I couldn't disable float, I set that value to about 12.8v. Low enough for no current to actually flow after it switched to it from a decent charge in the first place.
The low-voltage float setting will ALSO act as an emergency catch to help keep your battery from totally discharging if the battery DOES get low for some reason. NOW there will be current flowing, and keep them charged enough to prevent a total discharge.
So here's the deal where it gets all confusing - one *can* utilize controllers designed for lead-acid, provide we disable temp comp, and keep the float setting low - albeit float is not necessary in the truest sense of the word with LFP.
Shoehorning the features of a lead-acid controller into LFP use is what we're doing, but it takes a bit of knowledge to know if you can "get away with it." Heh, real-world vs the lab.
