Advice on battery setup
  • nithin
    • Mar 2018
    Hello,
    I am planning to setup a battery pack to be charged by a 100W solar panel that is made up of three sets of 4s 18650 cells in parallel(these to be specific: https://www.ebay.com.au/itm/Panasoni...53.m2749.l2649)
    Based on the battery specification and from what ever i understood and series and parallel connections, the above setup should give me a base voltage of 14.8V with peak at 16.8V and 10.2 mA current.
    My charge controller has the below ratings:
    Nominal Voltage: 12V / 2V Auto Recognigition
    Rated Charge Current: 30A
    Max PV Input Voltage: 50 VDC
    Equalization Voltage: Sealed: 14.6V; Gel-None; Flooded: 14.8V
    Boost Voltage: Sealed: 14.4V; Gel 14.2V; Flooded: 14.6V
    Float Voltage: 13.8V
    Under Voltage: 12V
    Self consumption: <13mA
    I am also planning to use 4s bms boards with each set of 4s cells.
    Could you please advice if i am on the right track or if i am going wrong in trying to set up a 12V battery back that i plan to run couple of water pumps on rated at 50W in total. Any suggestions would be useful. Thanks.
    PS: The place i am setting this up gets on average 8-9 hours on sunlight.
    Regards,
    Nithin.
    Waiting for someone schooled in Li batteries, all I know is that they are easy to light on fire.
    Building a bank out of a bunch of cells is not safe in my book, far too many connections to go bad and make smoke
      What part are you not understanding? It takes a 16.8 volt CC/CV source to charge the batteries. There is only one controller that can do that, a Genasun GV-10-Li-16.7V 10 amp controller using a 60 cell 160 watt panel.
      Bottom line is your panel and controller will not work.
      • nithin
        • Mar 2018
        Thank you for the feedback guys
        • Guest
          Li-ion has a different charging profile then Lead-Acid. Your need to get a charge controller that is compatible with Li-ion or use Lead-Acid batteries with the charge controller you have.
          • Higher Voltage
            • Sep 2017
            • 35
            I dont know much about li po but talk to this guy:https://www.youtube.com/watch?v=pYmu8CnnuNk
              Any why is he such a revered authority ?
              Because you are telling a neophyte to trust his house, life, and expensive gear to somebody that was able to set up a youfool acct.
