Oooh, nearly all my powerbanks cut-off load when i plugin the charge usb socket. I use some usb gadgets like ledlbulbs and i have to plugout the charge before i can load.
In fact my question is. Will it effect the li-ion battery when you load while charging? I usually discharge only 30%
With this module i can also load and if the incoming amps is higer than the load i think it will chage the li-ion also, with discharge protection
