The only graph in this thread that shows Voc versus SOC is my graph in the second post which does not tell you anything about internal resistance under load. If you mean the Winston graph, that is a set of discharge curves and shows battery voltage under various loads versus SOC. It has nothing to do with open circuit voltages.
For those that are interested, here is a link to an article on Discharge Curves, and other things about battery performance. http://www.mpoweruk.com/performance.htm
Simon
BMS - Homemade Battery logger https://github.com/simat/BatteryMonitor
Latronics 4kW Inverter, homemade MPPT controller
Simon
  is the coloumbic efficiency (pu)
 is the coloumbic efficiency (pu) is the amount of charge that exits the battery during the discharge cycle (C)
 is the amount of charge that exits the battery during the discharge cycle (C)  is the amount of charge that enters the battery during the charging cycle (C)
