Originally posted by Willy T
View Post
Using the EQ setting to do the balance is a great idea.
I tried to bottom balance @ 2.6 on 4 cells. As I recharged them I found that once the voltage gets above 3.460 one cell would climb very fast while the rest were 3.2 -3.3 v.
The other problem is that even if you do shut the controller down with some sort of cell monitoring system that at shutoff the weakest cell will be at 3.425 volts and the stronger cell might be at 3.3 volts. That means that every time you fully charge the battery which might be on a daily basis with an off-grid setup that you subject the weakest cell to 0.125 extra voltage. I think it is generally accepted that increase in voltage decreases the life of LFP batteries, 0.125 volts doesn't sound like much but over a ten year plus lifespan that one hopes one gets from these expensive batteries I think it could have an impact. Worst still is that you are subjecting the weakest cell to the extra stress.
Simon
