Hello, first time posting here
I am currently working on a project involving LiFePO4 batteries which will be charged by a solar panel. The batteries will at the same time provide power to a load circuit. This is the circuit i have made so far:
This circuit, if i have understood the datasheet correctly, will keep a regulated output voltage of around 3.6V, which is the voltage required to charge the LiFePO4 battery used in the application.
What i now need is a circuit to prevent overcharging and prevent undervoltage. The battery datasheet lists the "discharge cutoff" as 1.8V. Is this the lowest recommended voltage the battery can reach without damaging it? The solar panel in the project can not be changed for one with a higher voltage/power output, and the batteries has to be LiFePO4 type batteries. The entire purpose of the solar panel is to help extend the battery life of the batteries. The load in question will on average use around 1mA of current, with a maximum of 500mA for short periods.
I have been searching for battery management ICs, but have been unable to find any that provides overcharging and undervoltage protection for LiFePO4 type batteries. Does anyone have any suggestions as to how i can provide this protection to these batteries?
