Hi, everyone! I'm a newbie, and this is my first post here:
I'm looking to fit a work truck with solar panels, batteries, a charge controller, and an AC inverter. I wouldn't mind buying parts separately, but I must make sure they will work together.
I intend to use LiFePO4 batteries for their energy density. From what I understand I need the following components:
Charge controller (MPPT)
Batteries (LiFePO4)
Inverter (with LVC)
Solar panels
My question is this: does a combination charge controller and inverter exist? If I use a standard inverter, how do I protect the batteries from low voltage? Does a charge controller have DC outputs to go to an inverter? Is there a better option? What is the cost of such a device? Are there any limitations I should keep in mind (max number/voltage of PV panels, max number of batteries, etc.)?
Ideally, such a device would also allow AC grid charging when mains is available.
Thanks in advance for your help and advice!
Batteries (LiFePO4)
Inverter (with LVC)
Solar panels
