I am trying to diagnose whether I have damaged my new battery by discharging it. Here is a photo of the battery with the specifications and a photo of the current while discharging it.P1110362.JPGP1110365.JPG
To make a long story short, I bought it, used it to charge a phone at 280mA over 5 hours, then charged a few other things, then set it up outside with a solar panel project that failed (That's another story) but I think it became deeply discharged. I am not entirely sure but the standing voltage was at 11.7V.
Anyway, I put it on a charger yesterday and set the charger to 1.5A because that is what I read on the battery as the "Cyclic Usage" "Initial Current". I later read elsewhere that SLAs are limited to 10% of their amp hours. That would be 500mA. Did I make a mistake? The charger only supplied 1.4 amps to it for about 90 minutes, after which the current slowly decreased. A couple of hours later, it got down to 100mA then the charger shut off.
Now I am testing it for discharge. I set the unit at 1A but it will only supply 400mA discharging. Later it went up to 500mA but now it is back at 410mA.
What it the max. current the battery should supply? How can I tell if it is damaged? What should the max charge rate be?
