I have six L16 (6-volt) flooded lead/acid batteries that are over seven years old now and on their last legs. They are connected in pairs so that each pair is 12 volts. When I measured the battery voltages this morning, two of the pairs were out of balance. In the worst pair, one of the batteries read a little over 7 volts and the other battery read under 5 volts. The 7-volt battery was bubbling a lot more than any of the other batteries. What is the cause of this imbalance? Should I remove the batteries that read low from the system?
Another of the pairs reads about 6.5 volts vs. 5.25 volts. The other pairs are balanced at 6.25 volts each (or very close to that). When I measured the voltage for the pairs of batteries, each of the three pairs reads about 12.5 volts.
I took the voltage measurement during the morning, overcast sky, with a 700-watt solar array.
I know the batteries are way too old and need to be replaced. We are hoping to nurse them along for a few more months until funding becomes available so we can buy new ones.
Any suggestions?
Thanks,
Royce
Manager at Walnut Creek Center for Education and Research (WCCER)
Any suggestions?
Thanks,
Royce
