I have a little $40 (12v 1A) BatteryMinder trickle charger that has the desulfation pulsing stuff going on in it. I'm using it on two 12v deep cycle batteries in parallel that I'm pretty sure went into storage without a charge and caked up. I know they haven't had much use over their life.
Anyway, I noticed something a bit ago. When the BatteryMinder is charging the battery, my meter shows about 6.5V, up from 5V a few days ago, but the interesting thing is that when I disconnect the charger, the voltage in the battery RISES to about 8V and stays there. Any idea what would cause that behavior?
I have a 60W (12v 5A) charger showing up here shortly that I'll use on it to try and heat it up a little more aggressively to melt the sulfer with a good stout charge and then I'll put the BatteryMinder back on it, but I'm trying to wrap my head around how a battery bank would show a lower voltage while being charged and then a higher voltage when disconnected.
