Does anyone heat your batteries in a battery box?  What is your setup like?  I'm looking for examples and ideas.
I have two big forklift 48v batteries built into a box in an unheated garage. The system is from a set of DC Solar trailer parts.
The battery box is vented across the top of the cells. It should work passively by gravity and heat exchanged inlet & exhaust flow, and certainly does work with the exhaust fan controlled by the inverter/charger. The exhaust fan draws primarily across the top of the cells through two 1-1/2" copper tubes, but there's also a smaller tube down to the bottom to remove heavier than air gases. The batteries are insulated on the sides and bottom. There's airspace underneath where I can add a heater, and I could seal around the top edge of the insulation, keeping the venting on top separate from the heated bottom and sides.
For the lead, it should not have any potential ignition source. So a relay contact thermostat is out, and small incandescent bulbs are an equally bad idea. Maybe an old mercury thermostat would be fine, not sure about using that at 48v DC or 120v AC. A heater could run off either power source. I have some heater plates from a Nissan Leaf battery, they could work. And a remote temperature probe controller I'd need to buy.
Another item on my list is to get a lithium bank set up, and that will do most of the daily energy cycling. The lead would be there just for short term power draws and wouldn't cycle very deep most of the time. That would reduce the need for keeping the lead warm in winter. They would always be full, and the reduced capacity at lower temp shouldn't matter as they won't cycle too deep. So maybe I should get started on the lithium bank instead of a lead heater. The most elegant heater may be none. And, well, I'll definitely need one for the lithium in the cold garage, so hey I can still set up a heater.
Thanks!
Thanks!
 heated FLA battery enclosure
