Only getting a fraction of battery capacity
I looked at the walmart web page for this battery, and didn't see a listed ah rating. Given the battery is called EverStart, and it lists cold cranking amps, I still feel confident that your issue is with the batteries. Meaning they are an engine starting battery. If your holding to a budget, buy a pair of GC2 batteries from Sams Club. They are 6v 215ah @ 20h batteries and cost $90-$100. -
Yes, they're the Everstart 24DC, Walmart brand. They are marketed as a marine deep cycle, but it lists MCA (Marine Cranking Amps), and I believe this battery is really sorta a hybrid, more suited to deep discharge than a staring battery, but still made to be able to deliver those bursts charges for starting as well. It's supposedly designed for trolling, etc.Leave a comment:
Right off I wonder if you've purchased the wrong type of battery. Meaning a starting battery vs a RE type or golf cart type. Could you post the specific make and model of battery?Leave a comment:
Hi!
I'm new to the forum and also new to Solar (though I've done a good bit of research and testing for my system). I was wondering if you guys might be able to provide a little insight into something that has me scratching my head.
_specs_
Everstart (walmart) 24DC Marine batteries x 2, wired in parallel.
Each is rated at 105 AH @1a (which I find out later isn't standard. They're probably about 85 Ah when set to a 20hr rating.)
I don't take these below 12.1V (my usual current draw lowers the voltage by about .1 v, so at 12.1, I'm really at 50%)
Dokio 100W portable and foldable solar panels x 2
Practically speaking, I get about 100W total from these in the pacific NW, depending on the time of day. Input Amps during bulk charge tends to range from 8A-10A.
Dokio PWM 10A charge controllers x 2 (they came with the panels. I have both hooked up, as I was worried about exceeding the 10A rating if I did both panels with one controller.
_monitors_
I've three ways of monitoring power usage. I've the Voltage and Current readings on each of the charge controllers. I've a simple hall-effect monitor (not usually hooked up), and I've got A multi-function battery monitor that basically goes through a 100A rated shunt to give me Voltage, Amp, Watts and accumulated Wh as well as Ah. All three of these monitors agree on the amount of usage (within tolerances).
I'm running my laptop from this battery bank. On any average day I will use between 110-135 ish Wh, or 8-11 Ah, and the voltage will drop to between 12.1 and 12.3 normally, sometimes 12.4. I've tested the system to see how much my typical usage lowers the voltage just from the draw- ie... getting up at six am and looking at the voltage, then comparing it to what it had been the night before. Typically it will have raised by .1V to .2V depending on whether I was playing my game at the time I went to sleep. When recharging, it typically takes about 30% more power than I used before the controllers go to float charge. This actually seems about right, considering inefficiencies and how the recharging is accomplished, etc.
So all the numbers balance out within reason, and they've been confirmed seven ways from sunday. I even ran some tests using only my laptop battery over a period of time to confirm the wattage being drawn by the device. I wanted to make sure that the issue wasn't systemic.
You might already be able to see the issue. I'm only using about 10ah.. maybe up to 12, and I'm draining the batteries down to 50-70 percent.With two batteries in parallel, I should be getting about 100 Ah before I hit 50% (Considering that my laptop usage is about 1.5A on average). Even accounting for Wallmart's deceptive labeling, I'm not getting anywhere near close to what I should, and it's far enough off that I don't think the issue is with my numbers. I think I am missing something conceptually. 10 percent of the capacity I am expecting is just too far off.
Can any of you see where I am going wrong? If I had to guess, I would think that my assumption that the battery is charged when the controller switches to float is incorrect, and that the battery isn't actually being fully charged, and then this compounds over a couple of days. I -have- done tests to let the battery rest after the panels went to float, and that dropped nicely down to 12.7 after six hours or so, but I don't test that every time. I tested it once to confirm that what I expected to happen, was actually doing so.
In truth, I just can't think of anything else. I appreciate very much any help you might provide.
Sincerely, Angela
