Luminous tubular 2200 cycles @ 50% DoD
  • Filter
  • Luminous tubular 2200 cycles @ 50% DoD
    @ 50% DoD more than 2000 cycles, and @80% 1500cycles, too good to be true or not?
    I think it is made in India.
    • 150 Ah Rated Capacity @ C10, 12V
    • Warranty - 60* Months
    • Tubular plate Technology - Next generation tall tubular battery with better charge acceptance and long Back up
    • Long cycles (1500 @80% DOD, 5000 @ 20% DOD), ensuring design life
    • Longer life without discharge with self-discharge rate of 3% per month STC.
    • Efficient battery with Higher AH efficiency > 90%, and WH efficiency > 80%
    • Low maintenance with a topping frequency of 8-10 months, low maintenance with level indicators
    • Manufactured with high corrosion resistant and robust spine technology using the advanced and state-of-the-art 'HADI' high pressure (at 100 bar) spine casting machines, which ensure a super fine grain structure, for strength, long life and highest reliability
    • Designed with thicker positive plates and 20% more electrolyte to withstand power outage
    • It has high purity, corrosion-resistant proprietary spine alloy composition for long battery life
    • Extra-strong, flexible oxidation-resistant gauntlet for better performance and long life
    • Puncture-resistant polyethylene separator which minimize the possibility of internal short circuits.
  • #2
    Sounds like a battery worth looking into. Problem I'm having is finding them for sale in the USA and pricing in dollars.
    • #3
      * warranty 60 months
      What happens when you read that fine print on the warranty ? I'll bet it's no warranty at all.
      • #4
        I am not living in India. Seems they have a service department there https://www.luminousindia.com/war-ranty
        • #5
          Warranty said 36 mos. full replacement and the next 24 mos., pro rated. Still They don't appear to be available in the USA.
          • #6
            And lead is expensive to ship!
            • #7
              From their website. Why not USA?? 🤔
              • #8
                It could be Intellectual Property (IP) issues. They could be infringing on a prior patent and not worth the trouble and cost to pay licensing fees. Easier to build a market elsewhere and let the prior patent expire.
                • #9
                  Those are their distributors. If you want to be a distributor give them a call and they will oblige. Asian companies are very easy to do business with.
