Hello,
I have an off-grid sytem (solar + wind) and my battery bank (24V) is a 2S4P topology (so I have 4 strings of 2 x 12V batteries in parallel).
Recently, while being in a short vacation (abroad), I've noticed that the battery bank capacity was going down. I blame it on the very low outside temperatures (the batteries are located in my garage thus the indoor temperature did not felt bellow 10 deg celsius all this time).
Anyway, when I came home I faced a completely different reality: two of my batteries (from the same string) were boiling like hell.
When I've measured the voltages, one had 10.5V and the other one around 15V.
I've checked the water level and it was OK (I've done the same thing about 2 weeks before) thus there was no part of the internal plates exposed to the air.
I've removed the batteries from the bank and left them to cool off (it takes about one day!). I rechecked the voltages and this time and I've got around 9.5V and 11.5V.
I' ve tried to measure the SOC using a hydrometer and I found two cells with slighty lower indication in the first battery but the second one shown quite similar indication for all the cells. Anyway, both batteries shown a SOC bellow 50% or something.
I was pretty confused, as I was expecting the "good" battery to be in an overcharged state (maximum SOC indication).
Anyway, in the next few days, I've tried to slowly charge this "good"(??) battery using various scenarios (constant low current, high pulse charging and so on) but it seems to stall at 12.8V. I left it disconnected for a day and the indication was around 12V.
That's pretty confusing too, as there's no indication of a bad (shorted) cell or deep sulfation.
So I came here to kindly ask you to enlighten me on this matter: what supposed to be the effect of that heavily boiling (for at least two days, I presume)? Like I've just said, the electrolyte level wasn't bellow minimum and the whole battery case was quite hot to touch (maybe 45-50 deg celsius?).
Do you have any advice on how to recover this battery (as I already have an identical one in very good shape - it has been used alone in a 12V back-up system, powering up my routers, cctv and such). I'd like to put them back in the missing string and, as I'll have to relocate during this year, I don't want to spent any more money on two brand new ones.
Btw, for the same relocation reason, I went with marine (I know..) batteries so they have pretty slim Pb plates inside (for your information). Thanks in advance for your time.
