24v battery bank not the same voltage ,
  • joshhopey
    • Sep 2016
    • 5
    hi i got 8 batteries in series 12v each to make 24v ,
    when charging , the batteries voltage when testing the 12v voltage
    1 battery is 12.93 and the 2nd battery is 13:10 , but when you check the two batteries in series , to make 24v , they the same as the rest off the bank , is this normal for 24v bank ? do you recommend battery battery balancer for them ? like theses http://www.ebay.co.uk/itm/24V-Solar-...UAAOSwNRdX~2bu
    No you do not, or I should say you had better not have them all wired in series. If you have 8 - 12 volt batteries wired in series, you have 96 Volts. The only way to use 8 - 12 volt batteries to make 24 volts is a 2S4P configuration. That means 2 in series per string, and 4 parallel strings.
    This suggest to me you just might have all 8 batteries wired in series. Would explain your question and confusion.
    Your batteries should be wired as shown below, just add 2 more strings to make 4 parallel strings That is 2 in series, 4 in parallel aka 2S4P or 2 x 4. You do not need anything other than to learn what you are doing.
    • joshhopey
      • Sep 2016
      • 5
      hi thanks for replay sorry forgot to say it series and parallel , it just one battery atm resting is 12:53 and the other one is at 12:61 ? is that okay > note they are in series . and parallel , im wondering if you got skype so i could show you a video off it , many thanks my skype is joshhopey
        That says you need to EQ the batteries with your generator and battery charger. Cannot be done with Solar. You need a stiff source of power for 24 hours. Solar cannot do that as it only provides full power for 1 hour or less.
        • joshhopey
          • Sep 2016
          • 5
          hi mate i dont have alot off money will this battery charger work say im only 19 im still new to this http://www.ebay.co.uk/itm/10AMP-12V-...IAAOSw~gRVu2~i
          • John Galt 1
            • Dec 2016
            • 68
            How long have the batteries been resting before checking the voltage? You really need to let them rest at least 4 hours and overnight is better if you intend to use voltage as the testing method.
            ​If these are LA (lead acid) batteries a hydrometer is a much more accurate way to test their condition.
            ​If you do decide to equalize them please don't EQ them for 24 hours. If they don't come back within 1-4 hours they aren't going to get any better and a 24hr EQ will seriously reduce their life. And yes, solar is capable of holding a several hour EQ on a sunny day if you've got enough panels to hold the EQ voltage. Using solar to equalize during short winter days can be harder.
            • joshhopey
              • Sep 2016
              • 5
              hi john they been resting for 42 hours , no voltage drop . im just ordered a 20 amp 24v battery charger and i will leave it on charge for 24 hours , i installed two new batteries and then it came out off balance hopefully onced i charged it on mains it should sort it self out
