Hi all,
The past few months my battery bank give me a lot of charging problems due to what I believe is sulfation. I begin to research the new Trojans Smart Carbon Technology. I couldn't find much information on the web so I email Trojans battery support to get some answers.
I thought some of the members of this forum may be want to know this new technology, so I copy and paste the emails below:
Hi,
I like to know how smart carbon work, and how end user help to make sure the battery to last as long as it possible. I want to know when the battery in PSOC what the soft sulfur do? do they turn hard in the electrolyte or they stay soft cbecause there isn't any negative lead plate to stick them self to? How long can the battery stay in PSOC before a full 100% charge is required? Thank you.
Answer,
Subject: Request for more information received
Date: Thu, 1 Oct 2015 00:29:13 +0000
Thanks for your interest in Trojan Battery.
Smart carbon works making it easier for the sulfate to dislodge when finally that part of the battery get charged.
When a battery is discharged it is discharged at random and the discharge is just the sulfuric part of the acid getting into the sponge lead. If that part of the battery is not charged in several hours, then the sulfate may become too solid for the charging process to take it back to the sulfuric acid. In reality killing that small part of the battery.
Smart carbon, only works for battery in PSOC as if the battery is always fully charged, then there is not sulfating to help dislodge.
For a battery to last the longest we need several things.
a) Battery should be at 25C. For each 10C over 25C the battery life is reduced in half. Ex. At 35C a battery will last only 50% than at 25C under the same circumstance.
b) Battery should be charged with the correct charging algorithm, not to head up the battery or not to undercharged. This will include equalizing the battery if is not a VRLA.
c) Battery should be charged to 100% as soon as possible, the normal battery state should be charged, even if we only have one hour, battery will like to be charged for that hour. That prevent sulfation.
d) Battery should be discharged to a max of 50%, the less discharge the more a battery will last.
Thanks
Best Regards
Hi Ramon,
Thank you for your quick reply regarding my questions about the Smart Carbon Technology your company use in your Premium and Industrial line batteries. I understand most of the answers you gave me, but since English is not my first language there are something I still need you to clarify for me. May be I need to put my question in different way so you can help me to understand fully.
On your last Email you said;
Let me see if I can understand you on this one,
1, because of Smart Carbon, The sulfuric can not get into the sponge lead, or it can’t stick to the lead, so it can’t kill that part of the battery?
Answer: With smart carbon, the sulfuric will get into the sponge lead as usual, but will not stick so quick to the lead. Think of it as carbon molecules between the lead and the molecules of the sulfuric to prevent the sulfuric to stick too hard to the lead.
2, So is the Smart Carbon immune to sulfation? Or it just make it longer to sulfate the battery so we the user can full charge the battery in time to avoid the sulfation.
Answer: It is just make it longer to sulfate the battery so the user can full charge the battery in time to avoid sulfation.
3, If the Smart Carbon is only slow down the sulfating process not totally immune, how long can the battery in PSOC before it cause sulfation problem? Few days or weeks? The reason I ask is that where I live, we have evry good insolation, but the same time we also have a lot of cloud passing by each day and sometime a lot of overcast. My panels are over sized because of the clouds, if the battery can stay few days PSOC. The panels will be able to charge the battery back to 100% eventually.
Answer: A few days, the issue is that the battery discharge and charge at random. Two cycles at same DOD with one PSOC in the middle will give us different results. But in general if the battery is fully charge on Monday and fully charge back again on Thursday. With smart carbon you battery life will good.
4, As you said in your earlier Email, the battery will last much longer if it stay in the 25C degree. But Absorption charge usually sent up the temperature substantially. If I can make the battery stay in PSOC state most of the time, It will make the battery stay cool most of the time. Do you recommend I should make the battery stay in PSOC most of the time or I should charge back the battery to 100% ASAP when I got your batteries?
Answer: Please let your charger know the battery brand and model it is charging. ALL batteries have a different charging algorithm, but most battery manufacture have an average algorithm that will enhance your battery life. Battery as people will last longer due to what they eat. Never prevent the battery to be fully charge due to temperature, just adjust or change the charger, it is less expensive.
Hi,
Answer,
Thanks
Best Regards
Hi Ramon,
