according to SKs sticky batteries marketed as marine with an RC rating is a hybrid. i doubt SCA are going to ruin their brand perpetrating fraud. anyone stuck out in the pacific ocean with a dead SLI battery they bought from SCA marketed as a marine would quickly see SCA out of business. i now have a 160ah 24v hybrid bank so the discharge on the coffee machine would be c/3. also according to SKs sticky a discharge for hybrids up to c/2 is ok
12v marine battery in series with 12v deep cycle
* Hybrid Batteries .. but on the charge/discharge side of FLA hybrids you can go as high as C/4, and some cases C/2. This makes them very useful for folks who use over sized Inverters or have to use high charge rates because of low Sun Hours in winter.
just what i needComment
No one in their right mind would use that battery for Marine or 4x4. For the same physical size you can more cca and ah in a quality semi sealed calcium type battery. Those are own branded sca, or in full super cheap auto. Sca would not be liable if they fail other than to replace a faulty item.according to SKs sticky batteries marketed as marine with an RC rating is a hybrid. i doubt SCA are going to ruin their brand perpetrating fraud. anyone stuck out in the pacific ocean with a dead SLI battery they bought from SCA marketed as a marine would quickly see SCA out of business. i now have a 160ah 24v hybrid bank so the discharge on the coffee machine would be c/3. also according to SKs sticky a discharge for hybrids up to c/2 is okComment
+1No one in their right mind would use that battery for Marine or 4x4. For the same physical size you can more cca and ah in a quality semi sealed calcium type battery. Those are own branded sca, or in full super cheap auto. Sca would not be liable if they fail other than to replace a faulty item.
They have no particular liability if you choose to use the wrong kind of battery, even if it is based on their naming of the battery.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
im not using it for as a marine battery, you stated its an SLI which it is not. its a hybrid. physical size does not matter because im not using it in a 4x4 . price matters its cheap, its working well, its only discharging to 80% overnight, recharging to 1.260 within 2-3hrs.No one in their right mind would use that battery for Marine or 4x4. For the same physical size you can more cca and ah in a quality semi sealed calcium type battery. Those are own branded sca, or in full super cheap auto. Sca would not be liable if they fail other than to replace a faulty item.
here are a couple of reviews using similar batteries from SCA for running fridges and other accessories .
http://www.aulro.com/afvb/technical-...-any-good.htmlComment
No at your price point and not made in Down Under.
There are only two manufactures I know of that make an AGM that can even remotely handle C/2 for any given length of time, and you do not have them unless they are Concorde Aircraft Military grade or Optima Blue Tops.MSEE, PEComment
ok, by "any length of time" do you mean sustained? how about 15secs bursts like using an 1800w (75amp at 24v) chainsawNo at your price point and not made in Down Under.
There are only two manufactures I know of that make an AGM that can even remotely handle C/2 for any given length of time, and you do not have them unless they are Concorde Aircraft Military grade or Optima Blue Tops.Comment
