I own a CyberPower PP2200SW battery backup, and I would like to expand the battery storage and charge it with a solar panel. I want to use a MPPT charge controller, but I need to know if I need more than one.
I assume that the four 12V batteries in the UPS are in series, so in addition to connecting additional batteries in parallel with each existing battery to expand capacity, I need to know how to connect charge controller(s) to keep the array topped.
Will the following schematic work?
Additionally, if I use multiple charge controllers, is it safe to connect all four charge controllers to the same solar panel? Or do I need one panel for each controller?
Lastly, if I want a 12V source, can I connect the output from all charge controllers together without worrying that the controller will cause an internal short?
Code:
A B C D E
(+48V) -> [+12V-] <-> [+12V-] <-> [+12V-] <-> [+12V-] <- (-48V)
A - First charge controller (+) and UPS (+)
B - First charge controller (-) and second charge controller (+)
C - Second charge controller (-) and third charge controller (+)
D - Third charge controller (-) and fourth charge controller (+)
E - Fourth charge controller (-) and UPS (-)
