The concrete floor thing is an old wives tale that seems to never go away.
Important though is a well ventilated location - with flooded cell batteries hydrogen can be generated and it needs to escape. It will go 'up and away' but could be trapped in an unventilated area.
Hydrogen is really quite safe but as with and thing of that nature the rules must be followed. You don't sit around throwing matches into a barrel of gas for a good reason - eventually one of them will not go out!
Where to keep batteries?
You can place your batteries anywhere which is isolated from heat and is a cool and dry place..So you can go ahead with your idea of storing it in your garage..Thank you..Leave a comment:
A cool and dry place has nothing to do with a battery generating gas (hydrogen in particular).Leave a comment:
As long as the batteries are stored in a cool dry place, you should be fine.Leave a comment:
Run 2" or 3" tube, always ascending, to vent the gas from the top of each bin.
OR
There is a company called Zephyrvent for PV battery arrays, with a 4" vent and brushless DC fan driven by the charge controller.
Any simple affective designs to vent gas? I was considering plastic bins with snap on cover and some kind of tubing. Hydrogen is light right? So If I run some tubing from the basement straight outside it may work? I'm weary of using a small fan inside tubing, it would be a source of ignition.Leave a comment:
More than a fire hazard, hydrogen generated by a charging lead acid battery is an explosion hazard.
H2 easily collects in an unventilated area and any time there is an explosive mix plus ignition source (and a spark from static electricity is adequate) there can be a rather violent boom.
Industrially it is less of a problem as people will be trained on how to handle hydrogen. Residentially it could be a bit of a mess.Leave a comment:
Ok so if I buy a electric battery powered tractor like the Ariens AMP. I could store it safely outside in a shed during the winter in freezing conditions, if the batteries were charged? It seemed to me it would be a hassle to yank the batteries out after every season.Leave a comment:
Read beginning page 58
Plastic battery storage containers are cheap & good. They protect against incidental contact, acid-spills, battery rupture & properly vent any generated hydrogen. Get them at any auto-parts store.
If sitting on a cold surface, provide thermal insulation using high-density Styrofoam insulation (SM) Do not use wood (combustible).
Make sure your fusing & ground tie-in is immediately adjacent to & 100% accessible.
Wet-cell lead acid batteries produce hydrogen gas, which if contained may pose a serious fire hazard. Make sure your battery storage location is properly ventilated.
MLeave a comment:
I can't see your photo (nanny filter @ work)
Make your long run, your highest voltage, if you can't get larger wires in there.
I'm building a small system in/under a outbuilding, and the batteries will be outdoors, underneath the tool shed. That's where they are.Last edited by Mike90250; 11-24-2009, 02:21 PM.Leave a comment:
Off-grid signage lighting and batteries
This thread about outdoor vs. indoor use of batteries is perfect timing. I'm in the process of building a display (see attached photo) and need to deal with batteries. The underground cable that is already in place is 10 gauge and the distance is about 70 feet from the building. Running DC will require a larger more expensive cable.
My plan was to build a small "house" for the batteries and on it's roof add some other solar items such as a Sun Tunnel and an SRS solar powered vent (switched).
I'm certainly not the first to want to house batteries outside. I'll likely be powering a series of LEDs to minimize draw and to showcase what folks can do. It's a combination experiment and display for our retail showroom, destined to evolve as we play with it. I have an extra mod-sine wave inverter I will use and I have 4 - 6V golf cart style batteries I was going to try. Bad idea?
If it were you, how would you approach this?
Much appreciated.Attached FilesLeave a comment:
I think that pretty well answers my question, Mike.... Garage it is. I don't know what the temps in the garage are, but - I certainly can snug battery boxes up against the garage wall that is the wall for the crawl space under the house. Appropriate simple insulation, and viola, I'd bet you a steak that it would stay 30F+...
batteries loose capacity in the cold, so keeping them above 40F is nice.
Long cables, cause losses in the wires, unless you use even heavier wire then normal
Charged batteries will not freeze till -40F, half charged will not freeze at 0f
What are your garage temps in the winter?
If you just have a couple batteries, boat shops have plastic battery boxes that are good containers for batteries. If you have a lot, the large rubbermaid totes work well. You want to contain the contents if something happens to a battery and it leaks.
Is this off grid, or grid tie ?
links:
http://www.windsun.com/Batteries/Battery_FAQ.htm (short & sweet)
http://www.batteryfaq.org/ (very large)
http://www.smartgauge.co.uk/batt_con.html (connect batteries on diagonal, + )Last edited by Mike90250; 11-23-2009, 10:52 AM.Leave a comment:
Would someone please discuss environmental temperature, and battery performance and life, please. I too am considering where to locate my battery bank. In the garage is the simplest (and would have the shortest wire runs to the inverter) - but...... Another choice would be a "battery house" outside - snugged up to a wall of the house, for instance.
Very cold climate - winter night temps -20 (F) and day temps 10 are common, mid-November until mid-February. Overnight low 7F last night, for instance.
TIA for all thoughts.Leave a comment:
