Golf Cart Batteries and Inverters
Makes no difference. What it is telling you is you have generator with a poor Frequency control. You got what you paid for a Harbor Fright product. Really dropping from 60 Hz to 58 Hz is not an issue under heavy load.
But if you insist on 60 Hz buy a larger generator from a reputable manufacture in the USA. You get what you pay for.
MSEE, PEComment
I get 3 Hz shift from full (2500w) to 0 load with antique 6hp diesel. 5 Hz shift is no big deal at all, only issues would be AC powered clocks will have a bit of error. My inverter runs at 59.98 Hz and I have to reset clocks once a month or so..Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If I use correct punctuation while posting to this forum on my iPhone it thinks Im a spammer or hacker so I should buy an android phone? Uh yeah right.Comment
My generator is 13,500 peak and 11,000 running watts. Its a 75 foot run from the generator to the transfer switch. Id like to use number 8 THHN instead of number 6 for the 75 foot run. Number 6 is $490 and number 8 is only $106. Is number 8 ok to use?Comment
Thats three times this site has cut off my post for using an apostrophe.
That's because your post has non windows, non standard characters in it, and the site filter thinks it's a spammer trying to use foreign letters and numerals to create posts
Try writing in the simplest word processor (windows notepad) and copy and paste from there, works like a champ, unless you set windows up with foreign character sets.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Edit: The number 6 is $60 more so I bought that.Last edited by BigRich; 04-22-2018, 02:54 PM.Comment
