over charger batteries???? 12v now is over 17v??????:(
You are joking right? 85 watts? At 85 watts the most current you can generate is 7 amps at 12 volts. You need 6000 watts of solar panels and 320 amps to charge your batteries with.
With what you have now is not even enough to charge 1 battery you have now let alone 20 of them.MSEE, PEComment
??only one batery....
so there is something wrong with my bateries...?You are joking right? 85 watts? At 85 watts the most current you can generate is 7 amps at 12 volts. You need 6000 watts of solar panels and 320 amps to charge your batteries with.
i dont have 6000 watts on solar panels...?Comment
You could say that, you have 19-2/3 too many of them for a 80 watt panel
With the amount of battery capacity you have, you need 6000 watts of solar panels to keep them charged.
With an 80 watt panel, all you need is one single 12 volt 80 to 100 amp hour battery, and a 10 amp charge controller. With that setup you can power your computer for about 2 hours per day and that is it. So what I am telling you with your 80 watt solar panel is it is not even large enough for just 1 of your batteries. You would need a 300 watt panel for each one of your batteries, or 6000 watts to run your 20 batteries.MSEE, PEComment
ANOTHER problem?? solar panel
when i disconected the cables from the charger controllerIt is not mean, it is fact. If you have 20 of the 12 volt 300 AH batteries you need 6000 watts of solar panels and a minimum of 6 80 amp charge controllers. Not 1 or 2 40 amp CC's, 6 of them with with 6000 watts of solar panels.
So something is very wrong with what you claim Just having 1 charge controller is not enough to even over come the self discharge rate. No chance you could have ever over charged the batteries to begin with.
i dont remember if i insulated the cables so didnt touch together??
now i conected the old charger controller
i not get in any kind signols
my voltemerter i should read any numbers right?Comment
I am going to LOCK this thread. It's going no-place.
Luisito - if you can get someone local to help you with your translations, and start this thread again, we will try to help.
But we need the following information about your gear and setup.
Loads: Size from the appliance nameplate and hours daily.
150W 4 hours
1/2 hp 90 minutes
Charge source
a) PV panels, the Vmp and Imp off the back of the panels
b) spec from AC charger or generator
Batteries:
a) voltage
b) AH capacity
c) quantity (how many batteries in the bank)
System:
a) voltage
b) inverter input voltage, and output voltage and watts
c) charge controllerPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
