Hi All,
I'm currently experimenting with a small setup before moving to something larger.
My current configuration:-
1 x PWM Charge Controller (http://cgi.ebay.co.uk/270661620905)
1 x 7AH Gell Cell
1 x 60W Panel
This is used to control a PIR activated 12v fluoroescent tube in the garage.
My question is: will the PWM controller adjust charging rate for the low AH capacity battery? Or when low, will it pass the full current from the solar panel? Obviously I need to keep the charge rate around 0.1C otherwise I risk damaging the battery.
Will a PWM controller (especially a cheap chinese model - see above) do the required magic, or should I size my batteries (or solar panels) to maintain a balance of 0.1C charge current at peak conditions?
Thanks,
Steve
1 x 7AH Gell Cell
1 x 60W Panel
Thanks,
Steve
