Hope I get uploads right the first time.
Basically all I have is a dolly from Harbor freight ($39) that I converted to a portable battery bank system. I cut 2 x 4 boards and mounted to frame. it took (4). I bored holes in my boards for plus and minus poles. I added 2 x 4 sides to prevent any damage or shock to any one, basically encapsulating poles. The poles are aluminum and the size of a battery post. I bored a hole only 1/2 through the plywood floor so that poles could not go completely through. I placed a colored red and green cap on top of poles to indicate positive from negative and to prevent them from sliding out. I did have to cut a copper shim for each connector to make the connection tight to the pole. I was very easy to do.
I used quick release cable connectors ($5.99 ea) so I can remove and load the batteries easily, if I need to carry the battery-bank on a trip.
There is 1500 inverter mounted to top of the dolly also from Harbor freight and my controller is mounted on the back of the dolly.
I purchased two 6 foot #2 guage wires from HF and cut my own cables to make them up. They are all 15" long. I purchased battery boxes from Walmart. I also placed a plywood spacer between each battery so to let them vent-out the pre-made vents in the lids.
To me I wanted a way to carry and also have a safe setup for my batteries. Now I have my solar panels hooked to my battery-bank and running all my lights and such in my garage.
I hope this organizes and helps someone out there. Now let's get those pictures.
Crap only got 5 pics. I will do in two more post.
