If I have a bank of six 125 amp hour, 12 volt batteries, can I charge it with two different wind turbines?
One turbine may be designed with 6 blades to get power out of the lower winds and the other has just three the same type of blade for better output in mid and strong winds. Because of two different Perm. Magnet generator speeds, there would natually be different voltages, so wiring them in Parallel to a single controller just won't work, will it?
If the battery bank is wired in 12 volt parallel, can I mount a turbine controller on the front end of and the other turbine controller on the back posts of the same battery bank?
Bill
Bill
