For larger turbines, some folks swear by the Midnight Classic in wind turbine mode with the separate Clipper added on the turbine side to act as the dump load. It ends up being pricey but cast iron reliable and with networking capability as a simple option. In fact the Classic Light saves you money by leaving out the fancy direct control panel and using just the bus interface. Not quite sure what it takes to adapt that to IP, but it is designed for easy interface to computer, so how hard could it be?
Instead of 3x 80 watt panels, could you fit 1x240 on the existing frame? You can get a high voltage panel that needs an MPPT controller at a lower cost per watt than smaller battery voltage panels.
Can you give us the output specifications on the existing panels? You may not be getting best use from them as you have them wired now.
I know - or rather I think - only that they're BP 80 watt panels. When this site went up at the very beginning I was up to my eye-balls learning how to do wireless networking. Someone else took on establishing the site and the power supply and unfortunately he's no longer with us. I think the sticky id labels are still on the back of the panels and I'll note what they say next time I'm up there. I didn't even realise there were 'high' as opposed or 'low' or 'ordinary' or 'for suckers' panels.
Only consider going to 24 volt if the equipment takes ~50% of the current when being run at the higher voltage, otherwise you are wasting power instead of saving it. (Although you could use a 24v to 12v switching mode converter and maybe get more reliable power to the routers.)
Make sure that the vibration from the turbine will not shake up the panels or other equipment in a harmful way. And think about where the blades will end up of they snap off.
Oh, you can be sure that even if we set the wind-turbine up at the foot of the bloody mountain it would send a broken blade with unerring accuracy through the most expensive, delicate and vital piece of equipment we have.
Originally posted by Sunking;74535
Panel wattage required =
